# JavaScript Scripting
This add-on provides support for JavaScript (ECMAScript 2022+) that can be used as a scripting language within automation rules. It is based on GraalJS (opens new window) from the GraalVM project (opens new window).
This add-on includes by default the openhab-js (opens new window) NPM library and exports its namespaces onto the global namespace.
This allows the use of items, actions, cache and other objects without the need to explicitly import them using require().
This functionality can be disabled for users who prefer to manage their own imports via the add-on configuration options.
By default, the injection of the openhab-js (opens new window) NPM library is cached (using a special mechanism instead of require()) to improve performance and reduce memory usage.
When configuring the add-on, you should ask yourself these questions:
- Do I want to have the openhab-js namespaces automatically globally available (
injectionEnabled)?- Yes: "Use Built-In Variables" (default)
- No: "Do Not Use Built-In Variables", which will allow you to decide what to import and really speed up script loading, but you need to manually import the library, which actually will slow down script loading again.
- Do I want to have a different version injected other than the included one (
injectionCachingEnabled)?- Yes: "Do Not Cache Library Injection" and install your version to the
$OPENHAB_CONF/automation/js/node_modulesfolder, which will slow down script loading, because the injection is not cached. - No: "Cache Library Injection" (default), which will speed up the initial loading of a script because the library's injection is cached.
Note that in case you disable caching or your code uses require() to import the library and there is no installation of the library found in the node_modules folder, the add-on will fallback to its included version.
In general, the first run of a script will take longer than the subsequent runs.
This is because on the first run both the globals (like console) and (if enabled) the library are injected into the script's context.
# UI Based Rules
Advanced users, or users migrating scripts from existing systems may want to use File Based Rules for managing rules using files in the user configuration directory.
# Adding Triggers
# Adding Actions
Select "Add Action" and then select "Run Script" with "ECMAScript 262 Edition 11". It’s important this is "Edition 11" or higher, earlier versions will not work. This will bring up an empty script editor where you can enter your JavaScript.
You can now write rules using standard ES6 JavaScript along with the included openHAB standard library.
items.KitchenLight.sendCommand("ON");
console.log("Kitchen Light State", items.KitchenLight.state);
Sending a notification
actions.NotificationAction.sendNotification("[email protected]", "Balcony door is open");
var thingStatusInfo = actions.Things.getThingStatusInfo("zwave:serial_zstick:512");
console.log("Thing status",thingStatusInfo.getStatus());
See openhab-js (opens new window) for a complete list of functionality.
# UI Event Object
NOTE: Note that event object is different in UI based rules and file based rules! This section is only valid for UI based rules. If you use file based rules, refer to file based rules event object documentation.
Note that event object is only available when the UI based rule was triggered by an event and is not manually run!
Trying to access event on manual run does not work (and will lead to an error), use this.event instead (will be undefined in case of manual run).
This table gives an overview over the event object for most common trigger types:
itemState | sub-class of org.openhab.core.types.State (opens new window) | [item] changed, [item] was updated | State that triggered event | triggeringItem.state |
oldItemState | sub-class of org.openhab.core.types.State (opens new window) | [item] changed | Previous state of Item or Group that triggered event | previousState |
itemCommand | sub-class of org.openhab.core.types.Command (opens new window) | [item] received a command | Command that triggered event | receivedCommand |
itemName | string | all | Name of Item that triggered event | triggeringItem.name |
type | string | all | Type of event that triggered event ("ItemStateEvent", "ItemStateChangedEvent", "ItemCommandEvent", ...) | N/A |
Note that in UI based rules event.itemState, event.oldItemState, and event.itemCommand are Java types (not JavaScript), and care must be taken when comparing these with JavaScript types:
console.log(event.itemState == "ON") // WRONG. Java type does not equal with string, not even with "relaxed" equals (==) comparison
console.log(event.itemState.toString() == "ON") // OK. Comparing strings
console.log(event.itemState == ON) // OK. Comparing Java types
# Scripting Basics
The openHAB JavaScript Scripting runtime attempts to provide a familiar environment to JavaScript developers.
# let and const
Due to the way how openHAB runs UI based scripts, let, const and class are not supported at top-level.
Use var instead or wrap your script inside a self-invoking function:
// Wrap script inside a self-invoking function:
(function (data) {
const C = 'Hello world';
console.log(C);
})(this.event);
// Defining a class using var:
var Tree = class {
constructor (height) {
this.height = height;
# require
Scripts may include standard NPM based libraries by using CommonJS require.
The library search will look in the path automation/js/node_modules in the user configuration directory.
See libraries for more information.
# console
The JS Scripting binding supports the standard console object for logging.
Script logging is enabled by default at the INFO level (messages from console.debug and console.trace won't be displayed), but can be configured using the openHAB console (opens new window):
log:set DEBUG org.openhab.automation.script
log:set TRACE org.openhab.automation.script
log:set DEFAULT org.openhab.automation.script
The default logger name consists of the prefix org.openhab.automation.script and the script’s individual part .file.filename or .ui.ruleUID.
This logger name can be changed by assigning a new string to the loggerName property of the console:
console.loggerName = 'org.openhab.custom';
Please be aware that messages do not appear in the logs if the logger name does not start with org.openhab.
This behaviour is due to log4j2 (opens new window) requiring a setting for each logger prefix in $OPENHAB_USERDATA/etc/log4j2.xml (on openHABian: /srv/openhab-userdata/etc/log4j2.xml).
console.log(obj1 [, obj2, ..., objN])console.info(obj1 [, obj2, ..., objN])console.warn(obj1 [, obj2, ..., objN])console.error(obj1 [, obj2, ..., objN])console.debug(obj1 [, obj2, ..., objN])console.trace(obj1 [, obj2, ..., objN])
Where obj1 ... objN is a list of JavaScript objects to output.
The string representations of each of these objects are appended together in the order listed and output.
Note: openhab-js (opens new window) is logging to org.openhab.automation.openhab-js.
# Timers
JS Scripting provides access to the global setTimeout, setInterval, clearTimeout and clearInterval methods specified in the Web APIs (opens new window).
When a script is unloaded, all created timeouts and intervals are automatically cancelled.
# setTimeout
The global setTimeout() (opens new window) method sets a timer which executes a function once the timer expires.
setTimeout() returns a timeoutId (a positive integer value) which identifies the timer created.
var timeoutId = setTimeout(callbackFunction, delay, param1, /* ... */ paramN);
delay is an integer value that represents the amount of milliseconds to wait before the timer expires.
param1 ... paramN are optional, additional arguments which are passed through to the callbackFunction.
The global clearTimeout(timeoutId) (opens new window) method cancels a timeout previously established by calling setTimeout().
If you need a more verbose way of creating timers, consider to use createTimer instead.
# setInterval
The global setInterval() (opens new window) method repeatedly calls a function, with a fixed time delay between each call.
setInterval() returns an intervalId (a positive integer value) which identifies the interval created.
var intervalId = setInterval(callbackFunction, delay, param1, /* ... */ paramN);
The global clearInterval(intervalId) (opens new window) method cancels a timed, repeating action which was previously established by a call to setInterval().
# Accessing Variables
var myVar = 'Hello world!';
// Schedule a timer that expires in ten seconds
setTimeout(() => {
console.info(`Timer expired with variable value = "${myVar}"`);
}, 1000);
myVar = 'Hello mutation!'; // When the timer runs, it will log "Hello mutation!" instead of "Hello world!"
If you need to pass some variables to the timer but avoid that they can get mutated, pass those variables as parameters to setTimeout/setInterval or createTimer:
setTimeout((myVariable) => {
console.info(`Timer expired with variable value = "${myVariable}"`);
}, 1000, myVar); // Pass one or more variables as parameters here. They are passed through to the callback function.
myVar = 'Hello mutation!'; // When the timer runs, it will log "Hello world!"
This also works for timers created with actions.ScriptExecution.createTimer.
# Paths
For file based rules, scripts will be loaded from automation/js in the user configuration directory.
# Deinitialization Hook
It is possible to hook into unloading of a script and register a function that is called when the script is unloaded.
require('@runtime').lifecycleTracker.addDisposeHook(() => functionToCall());
// Example
require('@runtime').lifecycleTracker.addDisposeHook(() => {
console.log("Deinitialization hook runs...")
# JS Transformation
openHAB provides several data transformation services (opens new window) as well as the script transformations, that are available from the framework and need no additional installation. It allows transforming values using any of the available scripting languages, which means JavaScript Scripting is supported as well. See the transformation docs (opens new window) for more general information on the usage of script transformations.
Use JavaScript Scripting as script transformation by:
Creating a script in the
$OPENHAB_CONF/transformfolder with the.jsextension. The script should take one argumentinputand return a value that supportstoString()ornull:(function(data) { // Do some data transformation here, e.g. return "String has" + data.length + "characters"; })(input);Using
JS(<scriptname>.js):%sas Item state transformation.Passing parameters is also possible by using a URL like syntax:
JS(<scriptname>.js?arg=value). Parameters are injected into the script and can be referenced like variables.
Simple transformations can aso be given as an inline script: JS(|...), e.g. JS(|"String has " + input.length + "characters").
It should start with the | character, quotes within the script may need to be escaped with a backslash \ when used with another quoted string as in text configurations.
# Standard Library
The openHAB JavaScript library provides type definitions for most of its APIs to enable code completion is IDEs like VS Code (opens new window).
To use the type definitions, install the openhab npm package (opens new window) (read the installation guide (opens new window) for more information), and import the used namespaces with const { rules, triggers, items } = require('openhab'); (adjust this to your needs).
If an API does not provide type definitions and therefore autocompletion won't work, the documentation will include a note.
The items namespace allows interactions with openHAB Items.
Anywhere a native openHAB Item is required, the runtime will automatically convert the JS-Item to its Java counterpart.
- items :
object- .NAME ⇒
Item - .getItem(name, nullIfMissing) ⇒
Item - .getItems() ⇒
Array[Item] - .getItemsByTag(...tagNames) ⇒
Array[Item] - .addItem(itemConfig)
- .removeItem(itemOrItemName) ⇒
boolean - .replaceItem(itemConfig)
- .safeItemName(s) ⇒
string
- .NAME ⇒
var item = items.KitchenLight;
Calling getItem(...) or ... returns an Item object with the following properties:
- Item :
object- .rawItem ⇒
HostItem - .history ⇒
ItemHistory - .semantics ⇒
ItemSemantics(opens new window) - .type ⇒
string - .name ⇒
string - .label ⇒
string - .state ⇒
string - .numericState ⇒
number|null: State as number, if state can be represented as number, ornullif that's not the case - .quantityState ⇒
Quantity|null: Item state as Quantity ornullif state is not Quantity-compatible or without unit - .rawState ⇒
HostState - .members ⇒
Array[Item] - .descendents ⇒
Array[Item] - .isUninitialized ⇒
boolean - .groupNames ⇒
Array[string] - .tags ⇒
Array[string] - .getMetadata(namespace) ⇒
object|null - .replaceMetadata(namespace, value, configuration) ⇒
object - .removeMetadata(namespace) ⇒
object|null - .sendCommand(value):
valuecan be a string, atime.ZonedDateTimeor aQuantity - .sendCommandIfDifferent(value) ⇒
boolean:valuecan be a string, atime.ZonedDateTimeor aQuantity - .postUpdate(value):
valuecan be a string, atime.ZonedDateTimeor aQuantity - .addGroups(...groupNamesOrItems)
- .removeGroups(...groupNamesOrItems)
- .addTags(...tagNames)
- .removeTags(...tagNames)
- .rawItem ⇒
// Equivalent to items.KitchenLight
var item = items.getItem("KitchenLight");
// Send an ON command
item.sendCommand("ON");
// Post an update
item.postUpdate("OFF");
// Get state
console.log("KitchenLight state", item.state);
See openhab-js : Item (opens new window) for full API documentation.
# itemConfig
- itemConfig :
object- .type ⇒
string - .name ⇒
string - .label ⇒
string - .category (icon) ⇒
string - .groups ⇒
Array[string] - .channels ⇒
string | Object { channeluid: { config } } - .metadata ⇒
Object { namespace: value } | Object { namespace: { value: value , config: { config } } } - .giBaseType ⇒
string - .groupFunction ⇒
string
- .type ⇒
Note: .type and .name are required.
Basic UI and the mobile apps need metadata.stateDescription.config.pattern to render the state of an Item.
// more advanced example
items.replaceItem({
type: 'String',
label: 'Hallway Light',
category: 'light',
groups: ['Hallway', 'Light'],
tags: ['Lightbulb'],
channels: {
profile: 'system:follow'
metadata: {
expire: '10m,command=1',
stateDescription: {
config: {
pattern: '%d%%',
// minimal example
items.replaceItem({
type: 'Switch',
metadata: {
stateDescription: {
config: {
pattern: '%s'
# ItemHistory
Calling Item.history returns an ItemHistory object with the following functions:
- ItemHistory :
object- .averageBetween(begin, end, serviceId) ⇒
number | null - .averageSince(timestamp, serviceId) ⇒
number | null - .changedBetween(begin, end, serviceId) ⇒
boolean - .changedSince(timestamp, serviceId) ⇒
boolean - .deltaBetween(begin, end, serviceId) ⇒
number | null - .deltaSince(timestamp, serviceId) ⇒
number | null - .deviationBetween(begin, end, serviceId) ⇒
number | null - .deviationSince(timestamp, serviceId) ⇒
number | null - .evolutionRateBetween(begin, end, serviceId) ⇒
number | null - .evolutionRateSince(timestamp, serviceId) ⇒
number | null - .getAllStatesBetween(begin, end, serviceId) ⇒
Array[HistoricItem] - .getAllStatesSince(timestamp, serviceId) ⇒
Array[HistoricItem] - .historicState(timestamp, serviceId) ⇒
HistoricItem | null - .lastUpdate(serviceId) ⇒
ZonedDateTime | null - .latestState(serviceId) ⇒
string | null - .maximumBetween(begin, end, serviceId) ⇒
HistoricItem | null - .maximumSince(timestamp,serviceId) ⇒
HistoricItem | null - .minimumSince(begin, end, serviceId) ⇒
HistoricItem | null - .minimumSince(timestamp, serviceId) ⇒
HistoricItem | null - .persist(serviceId)
- .previousState(skipEqual, serviceId) ⇒
HistoricItem | null - .sumBetween(begin, end, serviceId) ⇒
number | null - .sumSince(timestamp, serviceId) ⇒
number | null - .updatedBetween(begin, end, serviceId) ⇒
boolean - .updatedSince(timestamp, serviceId) ⇒
boolean - .varianceBetween(begin, end, serviceId) ⇒
number | null - .varianceSince(timestamp, serviceId) ⇒
number | null
Note: serviceId is optional, if omitted, the default persistence service will be used.
var item = items.KitchenDimmer;
console.log('KitchenDimmer averageSince', item.history.averageSince(yesterday));
The HistoricItem object contains the following properties, representing Item state and the respective timestamp:
state: State as stringnumericState: State as number, if state can be represented as number, ornullif that's not the casequantityState: Item state asQuantityornullif state is not Quantity-compatiblerawState: State as JavaStateobjecttimestamp: Timestamp astime.ZonedDateTime
var midnight = time.toZDT('00:00');
var historic = items.KitchenDimmer.history.maximumSince(midnight);
console.log('KitchenDimmer maximum was ', historic.state, ' at ', historic.timestamp);
See openhab-js : ItemHistory (opens new window) for full API documentation.
The Things namespace allows to interact with openHAB Things.
- things :
object- .getThing(uid, nullIfMissing) ⇒
Thing - .getThings() ⇒
Array.<Thing>
Calling getThing(...) returns a Thing object with the following properties:
- Thing :
object- .bridgeUID ⇒
String - .label ⇒
String - .location ⇒
String - .status ⇒
String - .statusInfo ⇒
String - .thingTypeUID ⇒
String - .uid ⇒
String - .isEnabled ⇒
Boolean - .setLabel(label)
- .setLocation(location)
- .setProperty(name, value)
- .setEnabled(enabled)
- .bridgeUID ⇒
var thing = things.getThing('astro:moon:home');
// Set Thing location
// Disable Thing
thing.setEnabled(false);
The actions namespace allows interactions with openHAB actions. The following are a list of standard actions.
Note that most of the actions currently do not provide type definitions and therefore auto-completion does not work.
# Audio Actions
# BusEvent
# Ephemeris Actions
Ephemeris is a way to determine what type of day today or a number of days before or after today is. For example, a way to determine if today is a weekend, a bank holiday, someone’s birthday, trash day, etc.
Additional information can be found on the Ephemeris Actions Docs (opens new window) as well as the Ephemeris JavaDoc (opens new window).
// Example
var weekend = actions.Ephemeris.isWeekend();
# Exec Actions
Execute a command line.
// Execute command line.
var response = actions.Exec.executeCommandLine(time.Duration.ofSeconds(20), 'echo', 'Hello World!');
# HTTP Actions
// Example GET Request
# ScriptExecution Actions
The ScriptExecution actions provide the callScript(string scriptName) method, which calls a script located at the $OH_CONF/scripts folder, as well as the createTimer method.
You can also create timers using the native JS methods for timer creation, your choice depends on the versatility you need.
Sometimes, using setTimeout is much faster and easier, but other times, you need the versatility that createTimer provides.
Keep in mind that you should somehow manage the timers you create using createTimer, otherwise you could end up with unmanageable timers running until you restart openHAB.
A possible solution is to store all timers in the private cache and let openHAB automatically cancel them when the script is unloaded and the cache is cleared.
When using createTimer, please read Accessing Variables to avoid having unexpected results when using variables in timers.
# createTimer
actions.ScriptExecution.createTimer(time.ZonedDateTime zdt, function functionRef, any param1, /* ... */ paramN);
actions.ScriptExecution.createTimer(string identifier, time.ZonedDateTime zdt, function functionRef, any param1, /* ... */ paramN);
createTimer accepts the following arguments:
stringidentifier (optional): Identifies the timer by a string, used e.g. for logging errors that occur during the callback execution.time.ZonedDateTimezdt: Point in time when the callback should be executed.functionfunctionRef: Callback function to execute when the timer expires.*param1, ..., paramN: Additional arguments which are passed through to the function specified byfunctionRef.
createTimer returns an openHAB Timer, that provides the following methods:
cancel(): Cancels the timer. ⇒boolean: true, if cancellation was successfulgetExecutionTime(): The scheduled execution time or null if timer was cancelled. ⇒time.ZonedDateTimeornullisActive(): Whether the scheduled execution is yet to happen. ⇒booleanisCancelled(): Whether the timer has been cancelled. ⇒booleanhasTerminated(): Whether the scheduled execution has already terminated. ⇒booleanreschedule(time.ZonedDateTime): Reschedules a timer to a new starting time. This can also be called after a timer has terminated, which will result in another execution of the same code. ⇒boolean: true, if rescheduling was successful
function timerOver () {
console.info('The timer expired.');
// Create the Timer.
var myTimer = actions.ScriptExecution.createTimer('My Timer', now.plusSeconds(10), timerOver);
// Cancel the timer.
myTimer.cancel();
var active = myTimer.isActive();
// Reschedule the timer.
myTimer.reschedule(now.plusSeconds(5));
# Semantics Actions
See openhab-js : actions.Semantics (opens new window) for complete documentation.
# Thing Actions
It is possible to get the actions for a Thing using actions.Things.getActions(bindingId, thingUid), e.g. actions.Things.getActions('network', 'network:pingdevice:pc').
See openhab-js : actions.Things (opens new window) for complete documentation.
# Transformation Actions
openHAB provides various data transformation services (opens new window) which can translate between technical and human-readable values. Usually, they are used directly on Items, but it is also possible to access them from scripts.
console.log(actions.Transformation.transform('MAP', 'en.map', 'OPEN')); // open
console.log(actions.Transformation.transform('MAP', 'de.map', 'OPEN')); // offen
See openhab-js : actions.Transformation (opens new window) for complete documentation.
# Voice Actions
# Cloud Notification Actions
Note: Optional action if openHAB Cloud Connector (opens new window) is installed.
For available actions have a look at the Cloud Notification Actions Docs (opens new window).
// Example
actions.NotificationAction.sendNotification('<email>', '<message>'); // to a single myopenHAB user identified by e-mail
actions.NotificationAction.sendBroadcastNotification('<message>'); // to all myopenHAB users
Replace <email> with the e-mail address of the user.
Replace <message> with the notification text.
# Cache
The cache namespace provides both a private and a shared cache that can be used to set and retrieve objects that will be persisted between subsequent runs of the same or between scripts.
The private cache can only be accessed by the same script and is cleared when the script is unloaded.
You can use it to e.g. store timers or counters between subsequent runs of that script.
When a script is unloaded and its cache is cleared, all timers (see createTimer) stored in its private cache are automatically cancelled.
The shared cache is shared across all rules and scripts, it can therefore be accessed from any automation language. The access to every key is tracked and the key is removed when all scripts that ever accessed that key are unloaded. If that key stored a timer, the timer is cancelled.
- cache :
object- .private
- .get(key, defaultSupplier) ⇒
Object | null - .put(key, value) ⇒
Previous Object | null - .remove(key) ⇒
Previous Object | null - .exists(key) ⇒
boolean
- .shared
boolean
- .private
var counter = cache.private.get('counter', () => ({ 'times': 0 }));
console.log('Count', counter.times++);
Example (Get a previously set object)
var counter = cache.private.get('counter');
if (counter === null) {
counter = { times: 0 };
cache.private.put('counter', counter);
# Time
openHAB internally makes extensive use of the java.time package.
openHAB-JS exports the excellent JS-Joda (opens new window) library via the time namespace, which is a native JavaScript port of the same API standard used in Java for java.time.
Anywhere a native Java ZonedDateTime or Duration is required, the runtime will automatically convert a JS-Joda ZonedDateTime or Duration to its Java counterpart.
var item = items.Kitchen;
console.log("averageSince", item.history.averageSince(yesterday));
# time.toZDT()
There will be times when this automatic conversion is not available (for example when working with date times within a rule).
To ease having to deal with these cases a time.toZDT() function will accept almost any type that can be converted to a time.ZonedDateTime.
The following rules are used during the conversion:
| Argument Type | Rule | Examples |
null or undefined | time.ZonedDateTime.now() | time.toZDT(); |
time.ZonedDateTime | passed through unmodified | |
java.time.ZonedDateTime | converted to the time.ZonedDateTime equivalent | |
JavaScript native Date | converted to the equivalent time.ZonedDateTime using SYSTEM as the timezone | |
number, bingint, java.lang.Number, DecimalType | rounded to the nearest integer and added to now as milliseconds | time.toZDT(1000); |
Quantity or QuantityType | if the unit is time-compatible, added to now | time.toZDT(item.getItem('MyTimeItem').rawState);, time.toZDT(Quantity('10 min')); |
items.Item or org.openhab.core.types.Item | if the state is supported (see the Type rules in this table, e.g. DecimalType), the state is converted | time.toZDT(items.getItem('MyItem')); |
String, java.lang.String, StringType | parsed based on the following rules; if no timezone is specified, SYSTEM timezone is used | |
| ISO8601 Date/Time (opens new window) String | parsed, depending on the provided data: if no date is passed, today's date; if no time is passed, midnight time | time.toZDT('00:00');, time.toZDT('2022-12-24');, time.toZDT('2022-12-24T18:30'); |
RFC String (output from a Java ZonedDateTime.toString()) | parsed | time.toZDT('2019-10-12T07:20:50.52Z'); |
"kk:mm[:ss][ ]a" (12 hour time) | today's date with the time indicated, the space between the time and am/pm and seconds are optional | time.toZDT('1:23:45 PM'); |
| ISO 8601 Duration (opens new window) String | added to now | time.toZDT('PT1H4M6.789S'); |
If no time zone is explicitly set, the system default time zone is used. When a type or string that cannot be handled is encountered, an error is thrown.
# toToday()
For example, if the time was 13:45 and today was a DST changeover, the time will still be 13:45 instead of one hour off.
var alarm = items.Alarm;
# isBeforeTime(timestamp), isBeforeDate(timestamp), isBeforeDateTime(timestamp)
Tests whether this time.ZonedDateTime is before the time passed in timestamp, tested in various ways:
isBeforeTimeonly compares the time portion of both, ignoring the date portionisBeforeDateonly compares the date portion of both, ignoring the time portionisBeforeDateTimecompares both date and time portions
timestamp can be anything supported by time.toZDT().
time.toZDT('22:00').isBeforeTime('23:00')
time.toZDT('2022-12-01T12:00Z').isBeforeDateTime('2022-12-02T13:00Z')
# isAfterTime(timestamp), isAfterDate(timestamp), isAfterDateTime(timestamp)
Tests whether this time.ZonedDateTime is after the time passed in timestamp, tested in various ways:
isAfterTimeonly compares the time portion of both, ignoring the date portionisAfterDateonly compares the date portion of both, ignoring the time portionisAfterDateTimecompares both date and time portions
// Equivalent to items.Sunset
time.toZDT().isAfterTime(items.getItem('Sunset')) // is now after sunset?
time.toZDT().isAfterDateTime('2022-12-01T12:00Z') // is now after 2022-12-01 noon?
# isBetweenTimes(start, end)
Tests whether this time.ZonedDateTime is between the passed in start and end.
However, the function only compares the time portion of the three, ignoring the date portion.
The function takes into account times that span midnight.
start and end can be anything supported by time.toZDT().
time.toZDT().isBetweenTimes('22:00', '05:00') // currently between 11:00 pm and 5:00 am
time.toZDT().isBetweenTimes(items.getItem('Sunset'), '11:30 PM') // is now between sunset and 11:30 PM?
// Equivalent to items.StartTime
time.toZDT(items.getItem('StartTime')).isBetweenTimes(time.toZDT(), 'PT1H'); // is the state of StartTime between now and one hour from now
# isBetweenDates(start, end)
However, the function only compares the date portion of the three, ignoring the time portion.
time.toZDT().isBetweenDates('2022-06-18', '2023-12-24') // currently between 2022-06-18 and 2023-12-24
# isBetweenDateTimes(start, end)
time.toZDT().isBetweenDateTimes('2022-06-18T22:00Z', '2023-12-24T05:00Z') // currently between 2022-06-18 22:00 and 2023-12-24 05:00
# isClose(zdt, maxDur)
var timestamp = time.toZDT();
// do some stuff
if(timestamp.isClose(time.toZDT(), time.Duration.ofMillis(100))) {
// did "do some stuff" take longer than 100 msecs to run?
# getMillisFromNow
var timestamp = time.ZonedDateTime.now().plusMinutes(5);
# Quantity
The Quantity class greatly simplifies Quantity handling by providing unit conversion, comparisons and mathematical operations.
A Quantity consists of a measurement and its Unit of Measurement (UoM) (opens new window), e.g. 5.7 m (the measurement is 5.7, the unit is m meters).
Internally using the openHAB QuantityType, which relies on javax.measure (opens new window), it supports all units and dimensions that openHAB supports.
If your unit is not listed in the UoM docs, it is very likely that it is still supported, e.g. the Angstrom Å for very small lengths (1 Å = 10 nm).
Anywhere a native openHAB QuantityType is required, the runtime will automatically convert the JS-Quantity to its Java counterpart.
# Creation
Quantity(value) is used without new (it's a factory, not a constructor), pass an amount and a unit to it to create a new Quantity object:
The argument value can be a Quantity-compatible Item, a string, a Quantity instance or an openHAB Java QuantityType (opens new window).
value strings have the $amount $unit format and must follow these rules:
$amountis required with a number provided as string$unitis optional (unitless quantities are possible) and can have a prefix likem(milli) orM(mega)$unitdoes not allow whitespaces.$unitdoes allow superscript, e.g.²instead of^2.$unitrequires the*between two units to be present, although you usually omit it (which is mathematically seen allowed, but openHAB needs the*).
Generally, you can expect a unit consisting of two (or more) units to need a *, e.g. Nm is N*m,
Nearly all Units of Measurement (UoM) (opens new window) are expected to work with Quantity.
ɡₙ (standard gravity) is known to not work.
// Allowed:
var qty = Quantity('5.75 m');
qty = Quantity('1 N*m');
qty = Quantity('1 m/s');
qty = Quantity('1 m^2/s^2');
qty = Quantity('1 m^2/s^-2'); // negative powers
qty = Quantity('1'); // unitless quantity
qty = Quantity(items.my_uom_item);
// Not allowed:
qty = Quantity('m');
qty = Quantity('1 Nm'); // * is required
qty = Quantity('1 m^2 / s^2'); // whitespaces are not allowed
qty = Quantity('1 m^2 s^2'); // / is required
qty = Quantity('1 m2/s2'); // ^ is required
Note: It is possible to create a unit-less (without unit) Quantity, however there is no advantage over using a number instead.
# Conversion
It is possible to convert a Quantity to a new Quantity with a different unit or to get a Quantity's amount as integer or float:
var qty = Quantity('10.2 °C');
qty = qty.toUnit('°F');
var intValue = qty.int;
var floatValue = qty.float;
toUnit returns a new Quantity with the given unit or null, if conversion to that unit is not possible.
# Comparison
Quantity provides the following methods for comparison:
equal(value)⇒boolean: thisQuantityequals tovaluegreaterThan(value)⇒boolean: thisQuantityis greater thanvaluegreaterThanOrEqual(value)⇒boolean: thisQuantityis greater than or equal tovaluelessThan(value)⇒boolean: thisQuantityis less thanvaluelessThanOrEqual(value)⇒boolean: thisQuantityis less than or equal tovalue
value can be a string or a Quantity, for the string the same rules apply as described above.
# Mathematical Operators
add(value)⇒Quantity:valuecan be a Quantity-compatibleItem, a string or aQuantitydivide(value)⇒Quantity:valuecan be a Quantity-compatible or NumberItem, a number, a string or aQuantitymultiply(value)⇒Quantity:valuecan be a Quantity-compatible or NumberItem, a number, a string or aQuantitysubtract(value)⇒Quantity:valuecan be a Quantity-compatibleItem, a string or aQuantity
For the string the same rules apply as described above.
See openhab-js : Quantity (opens new window) for full API documentation.
# Log
By default, the JS Scripting binding supports console logging like console.log() and console.debug() to the openHAB default log.
Additionally, scripts may create their own native openHAB logger using the log namespace.
var logger = log('my_logger');
//prints "Hello World!"
logger.debug("Hello {}!", "world");
# Utils
# File Based Rules
The JS Scripting binding will load scripts from automation/js in the user configuration directory.
The system will automatically reload scripts when changes are detected to files.
File based rules can be created in 2 different ways: using JSRule or the Rule Builder.
# JSRule
JSRules provides a simple, declarative syntax for defining rules that will be executed based on a trigger condition
var email = "[email protected]"
rules.JSRule({
execute: (event) => {
// Equivalent to items.BalconyLights.sendCommand("ON")
tags: ["Balcony", "Lights"],
Note: You can use the passed event object to get information about the trigger that triggered the rule.
See Event Object for documentation.
triggers.SystemStartlevelTrigger(40) // Rules loaded
triggers.SystemStartlevelTrigger(50) // Rule engine started
triggers.SystemStartlevelTrigger(70) // User interfaces started
triggers.SystemStartlevelTrigger(80) // Things initialized
triggers.DateTimeTrigger('MyDateTimeItem');
You can use null for a trigger parameter to skip its configuration.
# Rule Builder
Rules are started by calling rules.when() and can chain together triggers,
conditions and operations in the following pattern:
Rule are completed by calling .build(name, description, tags, id) , all parameters are optional and reasonable defaults will be used if omitted.
nameString rule name - defaults generated namedescriptionString Rule description - defaults generated descriptiontagsArray of string tag names - defaults empty arrayidString id - defaults random UUID
rules.when().item("F1_Light").changed().then().send("changed").toItem("F2_Light").build("My Rule", "My First Rule");
console.log(event);
Note that the Rule Builder currently does not provide type definitions and therefore auto-completion does not work.
# Rule Builder Triggers
when()or().channel(channelName)Specifies a channel event as a source for the rule to fire..triggered(event)Trigger on a specific event name
.cron(cronExpression)Specifies a cron schedule for the rule to fire..timeOfDay(time)Specifies a time of day inHH:mmfor the rule to fire..item(itemName)Specifies an Item as the source of changes to trigger a rule..for(duration).from(state).fromOn().fromOff().to(state).toOn().toOff().receivedCommand().receivedUpdate().changed()
.memberOf(groupName)Specifies a group Item as the source of changes to trigger the rule..for(duration).from(state).fromOn().fromOff().to(state).toOn().toOff().receivedCommand().receivedUpdate().changed()
.system()Specifies a system event as a source for the rule to fire..ruleEngineStarted().rulesLoaded().startupComplete().thingsInitialized().userInterfacesStarted().startLevel(level)
.thing(thingName)Specifies a Thing event as a source for the rule to fire.changed()updated()from(state)to(state)
.dateTime(itemName)Specifies a DateTime Item whose (optional) date and time schedule the rule to fire..timeOnly()Only the time of the Item should be compared, the date should be ignored.
Additionally, all the above triggers have the following functions:
.if()or.if(fn)-> a rule condition.then()or.then(fn)-> a rule operation.or()-> a rule trigger (chain additional triggers)
# Rule Builder Conditions
if(optionalFunction).stateOfItem(itemName)is(state)in(state...)
# Rule Builder Operations
then(optionalFunction).build(name, description, tags, id).copyAndSendState().copyState().inGroup(groupName).postIt().postUpdate(state).send(command).sendIt().sendOff().sendOn().sendToggle()
# Rule Builder Examples
}).build();
// Turn on the kitchen light at SUNSET (using the Astro binding)
rules.when().channel('astro:sun:home:set#event').triggered('START').then().sendOn().toItem('KitchenLight').build('Sunset Rule', 'Turn on the kitchen light at SUNSET');
rules.when().timeOfDay('21:00').then().sendOff().toItem('KitchenLight').build('9PM Rule', 'Turn off the kitchen light at 9PM', ['Tag1', 'Tag2']);
rules.when().cron('0 0 21 * * ?').then().send('300,100,100').toItem('HallLight').build('Pink Rule', 'Set the colour of the hall light to pink at 9PM', ['Tag1', 'Tag2'], 'MyCustomID');
rules.when().item('S1').changed().toOn().then().sendOn().toItem('HallLight').build('S1 Rule');
rules.when().item('HallLight').changed().to('300,100,100').if(fn).then().sendToggle().toItem('OutsideLight').build();
// Turn on the outdoor lights based on a DateTime Item's time portion
rules.when().dateTime('OutdoorLights_OffTime').timeOnly().then().sendOff().toItem('OutdoorLights').build('Outdoor Lights off');
rules.when(true).item('HallLight').receivedCommand().then().sendIt().toItem('KitchenLight').build('Hall Light to Kitchen Light');
rules.when(true).item('HallLight').receivedUpdate().then().copyState().fromItem('BedroomLight1').toItem('BedroomLight2').build();
# Event Object
NOTE: The event object is different in UI Based Rules and File Based Rules!
This section is only valid for File Based Rules.
If you use UI Based Rules, refer to UI based rules event object documentation.
When a rule is triggered, the script is provided the event instance that triggered it.
The specific data depends on the event type.
The event object provides some information about that trigger.
This table gives an overview over the event object:
| Property Name | Trigger Types | Description | Rules DSL Equivalent |
oldState | ItemStateChangeTrigger, GroupStateChangeTrigger | Previous state of Item or Group that triggered event | previousState |
newState | ItemStateChangeTrigger, GroupStateChangeTrigger | New state of Item or Group that triggered event | N/A |
receivedState | ItemStateUpdateTrigger, GroupStateUpdateTrigger | State of Item that triggered event | triggeringItem.state |
receivedCommand | ItemCommandTrigger, GroupCommandTrigger | Command that triggered event | receivedCommand |
itemName | Item****Trigger, Group****Trigger | Name of Item that triggered event | triggeringItem.name |
groupName | Group****Trigger | Name of the group whose member triggered event | N/A |
receivedEvent | ChannelEventTrigger | Channel event that triggered event | N/A |
channelUID | ChannelEventTrigger | UID of channel that triggered event | N/A |
oldStatus | ThingStatusChangeTrigger | Previous state of Thing that triggered event | N/A |
newStatus | ThingStatusChangeTrigger | New state of Thing that triggered event | N/A |
status | ThingStatusUpdateTrigger | State of Thing that triggered event | N/A |
thingUID | Thing****Trigger | UID of Thing that triggered event | N/A |
cronExpression | GenericCronTrigger | Cron expression of the trigger | N/A |
time | TimeOfDayTrigger | Time of day value of the trigger | N/A |
eventType | all except PWMTrigger, PIDTrigger | Type of event that triggered event (change, command, triggered, update, time) | N/A |
triggerType | all except PWMTrigger, PIDTrigger | Type of trigger that triggered event | N/A |
eventClass | all | Java class name of the triggering event | N/A |
module | all | (user-defined or auto-generated) name of trigger | N/A |
All properties are typeof string.
Please note that when using GenericEventTrigger, the available properties depend on the chosen event types.
It is not possible for the openhab-js library to provide type conversions for all properties of all openHAB events, as those are too many.
In case the event object does not provide type-conversed properties for your chosen event type, use the payload property to gain access to the event's (Java data type) payload.
Time triggers do not provide any event instance, therefore no property is populated.
# Advanced Scripting
# Libraries
# Third Party Libraries
Loading of third party libraries is supported the same way as loading the openHAB JavaScript library:
var myLibrary = require('my-library');
Note: Only CommonJS require is supported, ES module loading using import is not supported.
Run the npm command from the automation/js folder to install third party libraries, e.g. from npm (opens new window).
This will create a node_modules folder (if it doesn't already exist) and install the library and it's dependencies there.
There are already some openHAB specific libraries available on npm (opens new window), you may also search the forum for details.
# Creating Your Own Library
You can also create your own personal JavaScript library for openHAB, but you can not just create a folder in node_modules and put your library code in it!
When it is run, npm will remove everything from node_modules that has not been properly installed.
Follow these steps to create your own library (it's called a CommonJS module):
Create a separate folder for your library outside of
automation/js, you may also initialize a Git repository.Run
npm initfrom your newly created folder; at least provide responses for thename,versionandmain(e.g.index.js) fields.Create the main file of your library (
index.js) and add some exports:var someProperty = 'Hello world!'; function someFunction () { console.log('Hello from your personal library!'); } module.exports = { someProperty, someFunction };Tar it up by running
npm packfrom your library's folder.Install it by running
npm install <name>-<version>.tgzfrom theautomation/jsfolder.After you've installed it with
npm, you can continue development of the library insidenode_modules.
It is also possible to upload your library to npm (opens new window) to share it with other users.
If you want to get some advanced information, you can read this blog post (opens new window) or just google it.
# @runtime
One can access many useful utilities and types using require("@runtime"), e.g.
var { ON, OFF, QuantityType } = require("@runtime");
// var runtime = require("@runtime");
// var ON = runtime.ON;
// var OFF = runtime.OFF;
require("@runtime") also defines "services" such as items, things, rules, events, actions, ir, itemRegistry.
You can use these services for backwards compatibility purposes or ease migration from JSR223 scripts.
Generally speaking, you should prefer to use Standard Library provided by this library instead.
