# Google Assistant Action
Please be aware that the graphical user interface in the Google Home app or on Google Nest devices may not fully support interaction with some of the supported device types. We cannot influence this and rely on Google to implement user interfaces for more devices. Nevertheless, interaction via voice or in writing with Google Assistant should always work.
- Latest Changes
- General Configuration
- Item Configuration
- Switch
- Light
- Light as Group with separate controls
- Scene
- Outlet, Coffee_Maker, WaterHeater, Fireplace
- Valve
- Sprinkler, Vacuum, Washer, Dishwasher
- Lock
- SecuritySystem as Switch
- SecuritySystem as Group with advanced functionality
- Camera
- Speaker (volume control only)
- TV
- Fan, Hood, AirPurifier (only on/off or fan speed control)
- Fan, Hood, AirPurifier (extended control options)
- AC_Unit
- Awning, Blinds, Curtain, Door, Garage, Gate, Pergola, Shutter, Window
- Charger
- TemperatureSensor
- HumiditySensor
- ClimateSensor
- Thermostat
- Sensor
- Additional Configuration
- Setup & Usage of the Google Home App
- Example Voice Commands
- Frequently Asked Question
# Latest Changes
State of this document
This documentation refers to release v4.0.0 (opens new window) of openHAB Google Assistant (opens new window) published on 2024-05-31
# v4.0.0
- Breaking Changes
- Group members are now stored in customData. This means existing (group) devices will only work after a new SYNC
- The
modesconfiguration for Thermostats has been renamed tothermostatModes - The
speedsconfiguration for Fans will be renamed tofanSpeeds - As item types of group members will then be validated, users might see devices disappearing in Google Home if they used an unsupported item within a group device
- Please take a look at Migration Guide (opens new window) and check your configuration against the new constraints
- More details and other changes
- Item names for group members will be stored in customData to save a query request to openHAB when executing commands
- For commands that need the current state the query request is still needed (thermostat commands or relative volume)
- Also some other configuration options are stored in customData
- Item types of group members will now be validated
- Add a lot of new functionality to Fan devices (AirPurifier, Fan, Hood)
- OnOff (separate power switch if used as a group)
- FanSpeed (separate fan speed if used as a group)
- Modes (yes, for the first time modes are available)
- SensorState (for FilterLifeTime and PM2.5 - no clue how to query those)
- Add AC Unit device
- Basically just a combination of the extended Fan and the Thermostat with all control and config options of both
- Potential Issues
- As customData is limited to 512 bytes it could be an issue to store very long item names e.g. for devices with a lot of members like thermostat
# v3.9.0
- Prepared available configuration options for the upcoming rollout of v4
- Users can start adjusting their setup to use the new configuration options:
Thermostat:modeshas been renamed tothermostatModesFan:speedshas been renamed tofanSpeeds
# v3.8.0
- Added
colorTemperatureInverted=trueoption toSpecialColorLightallowing users to invert the percentage to Kelvin conversion for thelightColorTemperatureitem
# v3.7.0
- Adjusted
Fanto usesupportsFanSpeedPercentoption - Inverted
lightColorTemperaturepercentage range when usingcolorUnit="percent"withSpecialColorLight
# v3.6.0
- Added new device types
HumiditySensor&ClimateSensor - Changed trait of
TemperatureSensorto actually show a UI
# v3.5.0
ga="light"forSpecialColorLightis replaced byga="specialcolorlight"useKelvin=trueis replaced bycolorUnit="kelvin"- Support for color temperature in Mired added
# General Configuration
- The openHAB Cloud Connector configured using myopenHAB.org (opens new window) (Items do NOT need to be exposed to and will not show up on myopenHAB.org (opens new window), this is only required for the IFTTT service!)
- A Google account
- A Google Home / Nest Voice Assistant Device or the Google Assistant on your phone
# Switch
| Supported Items | Switch |
| Configuration | (optional) inverted=true/false(optional) checkState=true/false |
# Light
| Configuration | (optional) inverted=true/false(optional) checkState=true/false(optional) colorTemperatureRange="minK,maxK" |
Dimmer { ga="Light" }
# Light as Group with separate controls
| Supported Items | Group as SpecialColorLight with the following members:(optional) Number or Dimmer as lightBrightness(optional) Number or Dimmer as lightColorTemperature(optional) Color as lightColor(optional) Switch as lightPower |
| Configuration | (optional) colorUnit="percent/kelvin/mired"(optional) checkState=true/false(optional) colorTemperatureRange="minK,maxK"(optional) colorTemperatureInverted=true/false |
Important Hint: If you want to use lightColorTemperature, you must either set colorUnit to kelvin or mired or define a colorTemperatureRange, because colorUnit defaults to percent.
If you use colorUnit as percentage values, the lowest color temperature (warm light) will be converted to 0%, and correspondingly the highest color temperature (cold light) will be converted to 100%.
If you need the inverted values for your device, you can set colorTemperatureInverted=true. This will convert low Kelvin values to high percentage values and vice versa.
Group lightGroup { ga="SpecialColorLight" [ colorUnit="kelvin", colorTemperatureRange="2000,9000" ] }
Color colorItem (lightGroup) { ga="lightColor" }
Example of a light device where low Kelvin values (warm light) are represented by high percentage values in the color temperature item:
Group lightGroup { ga="SpecialColorLight" [ colorUnit="percent", colorTemperatureRange="2000,6500", colorTemperatureInverted=true ] }
Dimmer colorTemperatureItem (lightGroup) { ga="lightColorTemperature" }
In case you want to control multiple lights using one device with Google Assistant, you can apply the following pattern:
Group:Switch powerItems (lightGroup) { ga="lightPower" }
Group:Dimmer brightnessItems (lightGroup) { ga="lightBrightness" }
Group:Color colorItems (lightGroup) { ga="lightColor" }
Switch powerItem1 (powerItems)
Switch powerItem2 (powerItems)
Dimmer brightnessItem1 (brightnessItems)
Dimmer brightnessItem2 (brightnessItems)
Color colorItem1 (colorItems)
Color colorItem2 (colorItems)
# Scene
| Configuration | (optional) sceneReversible=true/false(optional) checkState=true/false |
Switch { ga="Fireplace" }
# Valve
# Sprinkler, Vacuum, Washer, Dishwasher
Switch { ga="Washer" [ inverted=false ] }
Switch { ga="Dishwasher" [ inverted=false ] }
# Lock
| Configuration | (optional) inverted=true/false(optional) checkState=true/false(optional) ackNeeded=true/false(optional) pinNeeded="1234" |
# SecuritySystem as Switch
| Configuration | (optional) inverted=true/false(optional) checkState=true/false(optional) ackNeeded=true/false(optional) pinNeeded="1234"(optional) pinOnDisarmOnly=true/false(optional) waitForStateChange="2" |
See SecuritySystem as Group for explanation on the configuration options.
| Supported Traits | ArmDisarm (opens new window) StatusReport (opens new window) |
| Supported Items | Group as SecuritySystem with the following members: Switch as securitySystemArmed(optional) String as securitySystemArmLevel(optional) Switch as securitySystemTrouble(optional) String as securitySystemTroubleCode(optional) Contact as securitySystemZone |
| Configuration | (optional) inverted=true/false(optional) checkState=true/false(optional) ackNeeded=true/false(optional) pinNeeded="1234"(optional) pinOnDisarmOnly=true/false (optional) waitForStateChange="2"(optional) armLevels="L1=Level 1,L2=Level 2"Specifically on Zone Contacts: (required) zoneType="OpenClose/Motion" (optional) blocking=true/false |
Configuring the SecuritySystem as a Group will enable a lot of advanced functionality.
The Switch and the Group configuration support the following configuration parameters:
checkState=truewill compare the current state with the requested one and responds accordingly.ackNeeded=truewill request an acknowledgement before performing an action.pinNeeded="1234"will request and check the configured PIN before performing an action.pinOnDisarmOnly=truewill enforce the PIN on disarming only. Arming will be done without the PIN.waitForStateChange=0defines the number of seconds to wait for the security system state to update before checking that the arm/disarm was successful. Defaults to 0 if not specified.
armLevels="Key=Label" - The label is used for commanding Google Assistant, the key is the matching value sent to openHAB.
When using arm levels, Google will send the mapped level ID (L1,L2 in below example) to the item tagged with securitySystemArmLevel when you use the arm command. It will then use the status of the item securitySystemArmed to confirm that arming was successful.
When arming and not using arm levels or disarming, Google will send ON/OFF to the item tagged securitySystemArmed.
If arming fails and blocking zones have been configured with securitySystemZone and blocking=true, Google will attempt to check for zones that are causing the arming to fail.
ga="securitySystemTrouble" and ga="securitySystemTroubleCode" are used in a StatusReport to report any errors on the alarm, e.g. a flat battery.
Group gHouseAlarm "House Alarm" { ga="SecuritySystem" [ pinNeeded="1234", armLevels="L1=Level 1,L2=Level 2" ] }
Switch alarmArmed (gHouseAlarm) { ga="securitySystemArmed" }
String alarmArmLevel (gHouseAlarm) { ga="securitySystemArmLevel" }
Switch alarmTrouble (gHouseAlarm) { ga="securitySystemTrouble" }
String alarmTroubleErrorCode (gHouseAlarm) { ga="securitySystemTroubleCode" }
Contact frontDoorSensor (gHouseAlarm) { ga="securitySystemZone" [ zoneType="OpenClose", blocking="true" ] }
# Camera
| Supported Items | String |
| Supported Items | Dimmer |
| Configuration | (optional) checkState=true/false(optional) volumeDefaultPercentage="20"(optional) levelStepSize="5"(optional) volumeMaxLevel="100" |
# TV
| Supported Items | Group as TV with the following members:(optional) Switch as tvPower(optional) Switch as tvMute(optional) Dimmer or Number as tvVolume(optional) String or Number as tvChannel(optional) String or Number as tvInput(optional) String or Number as tvApplication(optional) Player as tvTransport |
| Configuration | (optional) checkState=true/false(optional) volumeDefaultPercentage="20"(optional) levelStepSize="5"(optional) volumeMaxLevel="100"(optional) transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME"(optional) availableChannels="channelNumber=channelId=channelName:channelSynonym:...,..."(optional) availableInputs="inputKey=inputName:inputSynonym:...,..."(optional) availableApplications="applicationKey=applicationName:applicationSynonym:...,..."(optional) lang="en" |
Group tvGroup { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME", availableChannels="1=Channel1=NBC,2=Channel2=CBS", availableInputs="hdmi1=xbox:gaming,hdmi2=settopbox", availableApplications="spotify=Spotify:Music,netflix=Netflix:Chill" ] }
# Fan, Hood, AirPurifier (only on/off or fan speed control)
| Supported Items | Switch (no speed control), Dimmer, Number |
| Configuration | (optional) checkState=true/false(optional) fanSpeeds="0=away:zero,50=default:standard:one,100=high:two"(optional) lang="en"(optional) ordered=true/false |
If you do not specify the fanSpeeds option, Google will use and expect percentage values for the fan speed.
Otherwise, you will be able to set up and use human speakable modes, e.g. "fast" for 100% or "slow" for 25%.
fanSpeeds will be a comma-separated list of modes, where the mode value corresponds to the speed value to be passed to the device. The mode or value is followed by an equal sign to list different aliases separated by a colon sign.
So in the example stated below both "high" and "two" would set the speed to 100%.
Some devices may expect a specific value instead of a percentage, like "1" or "2" as speed values. In this case, you can adjust the configuration and replace the percentage values with the values that the device expects. (e.g.: fanSpeeds="0=away:zero,1=default:standard:one,2=high:two").
Dimmer { ga="Fan" [ fanSpeeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ] } # Using specific percentage values for the speed
Switch { ga="Hood" } # No speed control - only on/off
Dimmer { ga="AirPurifier" } # Using percentage values for the speed
Dimmer { ga="AirPurifier" [ fanSpeeds="0=away:zero,1=low:one,2=medium:two,3=high:three,4=turbo:four", lang="en", ordered=true ] } # Using specific speed modes/values, which differ from percentage
Switch { ga="AirPurifier" } # No speed control - only on/off
# Fan, Hood, AirPurifier (extended control options)
| Supported Traits | OnOff (opens new window), FanSpeed (opens new window), Modes (opens new window), SensorState (opens new window) |
| Supported Items | Group as Fan, Hood or AirPurifier with the following members:(optional) Switch as fanPower(optional) Dimmer or Number as fanSpeed(optional) Number or String as fanMode(optional) Number as fanFilterLifeTime(optional) Number as fanPM25 |
| Configuration | (optional) checkState=true/false(optional) fanSpeeds="0=away:zero,50=default:standard:one,100=high:two"(optional) fanModeName="OperationMode,Modus"(optional) fanModeSettings="1=Low:Silent,2=Normal,3=High:Night"(optional) lang="en"(optional) ordered=true/false |
When configuring a Fan (or similar device) as a group with the above listed members, you will gain more options to control the device. In addition to control power and speeds, you will also be able to set modes and query sensor information (if supported by Google).
For more information on the fanSpeeds configuration option, please take a look at the simple Fan device type.
With the fanModeName and fanModeSettings you can control specific modes. Currently, one mode type per device is supported that you can configure with a name and a list of settings. The first entry in the names field is used internally while any other following separated by comma will be a synonym to be used in commands. The settings list is a comma-separated list of value=name pairs. The name can also contain synonyms separated by a colon. In the listed example you could then say "Set OperationMode to Normal".
Hint: At the moment, sensor values will only be queriable by voice and will not show up anywhere in the Google Home app.
Group fanGroup { ga="Fan" [ fanSpeeds="0=away:zero,50=default:standard:one,100=high:two", fanModeName="OperationMode,Modus", fanModeSettings="1=Silent,2=Normal,3=Night", lang="en", ordered=true ] }
Switch powerItem (fanGroup) { ga="fanPower" }
Dimmer speedItem (fanGroup) { ga="fanSpeed" }
String modeItem (fanGroup) { ga="fanMode" }
Number lifetimeItem (fanGroup) { ga="fanFilterLifeTime" }
Number pm25Item (fanGroup) { ga="fanPM25" }
# AC_Unit
| Device Type | AC_Unit (opens new window) |
| Supported Traits | OnOff (opens new window), FanSpeed (opens new window), TemperatureSetting (opens new window), Modes (opens new window), SensorState (opens new window) |
| Supported Items | Group as AC_Unit with the following members:(optional) Switch as fanPower(optional) Dimmer or Number as fanSpeed(optional) Number or String as fanMode(optional) Number as fanFilterLifeTime(optional) Number as fanPM25(optional) Number as thermostatTemperatureAmbient(optional) Number as thermostatTemperatureSetpoint(optional) Number as thermostatTemperatureSetpointLow(optional) Number as thermostatTemperatureSetpointHigh(optional) Number as thermostatHumidityAmbient(optional) String or Number or Switch as thermostatMode |
| Configuration | (optional) checkState=true/false(optional) fanSpeeds="0=away:zero,50=default:standard:one,100=high:two"(optional) fanModeName="OperationMode,Modus"(optional) fanModeSettings="1=Low:Silent,2=Normal,3=High:Night"(optional) useFahrenheit=true/false(optional) maxHumidity=1-100(optional) thermostatTemperatureRange="10,30"(optional) thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto"(optional) lang="en"(optional) ordered=true/false |
The AC_Unit device is basically the combination of the Fan and the Thermostat device. For explanation on configuration options please take a look at both of them.
Group acunitGroup { ga="AC_Unit" [ fanSpeeds="0=null:off,50=slow,100=full:fast", fanModeName="OperationMode,Modus", fanModeSettings="1=Silent,2=Normal,3=Night", thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false, lang="en", ordered=true ] }
Switch powerItem (acunitGroup) { ga="fanPower" }
Dimmer speedItem (acunitGroup) { ga="fanSpeed" }
String modeItem (acunitGroup) { ga="fanMode" }
Number lifetimeItem (acunitGroup) { ga="fanFilterLifeTime" }
Number pm25Item (acunitGroup) { ga="fanPM25" }
Number ambientItem (acunitGroup) { ga="thermostatTemperatureAmbient" }
Number humidityItem (acunitGroup) { ga="thermostatHumidityAmbient" }
Number setpointItem (acunitGroup) { ga="thermostatTemperatureSetpoint" }
Number setpointItemLow (acunitGroup) { ga="thermostatTemperatureSetpointLow" }
Number setpointItemHigh (acunitGroup) { ga="thermostatTemperatureSetpointHigh" }
String modeItem (acunitGroup) { ga="thermostatMode" }
| Configuration | (optional) discreteOnly=true/false(optional) queryOnly=true/false(optional) inverted=true/false(optional) checkState=true/false |
Blinds and similar devices should always use the Rollershutter item type for proper functionality.
Since Google and openHAB use the opposite percentage value for "opened" and "closed", the action will translate this automatically.
Rollershutter { ga="Awning" }
Switch { ga="Door" }
Rollershutter { ga="Garage" }
Contact { ga="Gate" }
Rollershutter { ga="Window" }
# Charger
| Device Type | Charger (opens new window) |
| Supported Traits | EnergyStorage (opens new window) |
| Supported Items | Group as Charger with the following members:(optional) Switch as chargerCharging(optional) Switch as chargerPluggedIn(optional) Number or Dimmer as chargerCapacityRemaining(optional) Number or Dimmer as chargerCapacityUntilFull |
| Configuration | (optional) checkState=true/false(optional) isRechargeable=true/false(optional) unit="PERCENTAGE" |
The configuration option unit supports the following values: PERCENTAGE (default), SECONDS, MILES, KILOMETERS, KILOWATT_HOURS
The setting isRechargeable defaults to false if not explicitly set to true.
If no chargerCharging item is specified, the device will only support queries.
Group chargerGroup { ga="Charger" [ isRechargeable=true, unit="KILOWATT_HOURS" ] }
Switch chargingItem (chargerGroup) { ga="chargerCharging" }
Switch pluggedInItem (chargerGroup) { ga="chargerPluggedIn" }
Number capacityRemainItem (chargerGroup) { ga="chargerCapacityRemaining" }
Number capacityFullItem (chargerGroup) { ga="chargerCapacityUntilFull" }
# TemperatureSensor
| Supported Traits | TemperatureControl (opens new window), TemperatureSetting (opens new window) |
| Supported Items | Number |
| Configuration | (optional) useFahrenheit=true/false(optional) temperatureRange="-10,50" |
By default, the temperature range of a temperature sensor is set to -100 °C to 100 °C.
The reported state values have to fall into that range!
If you need to adjust the range, please add the config option temperatureRange="-20,40" to the item. Keep in mind that those values always have to be provided in Celsius!
Number { ga="TemperatureSensor" [ useFahrenheit=true, temperatureRange="-20,40" ] }
# HumiditySensor
| Supported Traits | HumiditySetting (opens new window) |
| Configuration | (optional) maxHumidity=1-100 |
Number { ga="HumiditySensor" }
# ClimateSensor
| Supported Traits | HumiditySetting (opens new window), TemperatureControl (opens new window), TemperatureSetting (opens new window) |
| Supported Items | Group as ClimateSensor with the following members:(optional) Number as humidityAmbient(optional) Number as temperatureAmbient |
| Configuration | (optional) useFahrenheit=true/false(optional) maxHumidity=1-100(optional) temperatureRange="-10,50" |
By default, the temperature range of a climate sensor is set to -100 °C to 100 °C.
Group sensorGroup { ga="ClimateSensor" [ useFahrenheit=true, temperatureRange="0,40" ] }
Number temperatureItem (sensorGroup) { ga="temperatureAmbient" }
Number humidityItem (sensorGroup) { ga="humidityAmbient" }
# Thermostat
| Supported Items | Group as Thermostat with the following members(optional) Number as thermostatTemperatureAmbient(optional) Number as thermostatTemperatureSetpoint(optional) Number as thermostatTemperatureSetpointLow(optional) Number as thermostatTemperatureSetpointHigh(optional) Number as thermostatHumidityAmbient(optional) String or Number or Switch as thermostatMode |
| Configuration | (optional) checkState=true/false(optional) useFahrenheit=true/false(optional) maxHumidity=1-100(optional) thermostatTemperatureRange="10,30"(optional) thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" |
To set the temperature range your thermostat supports, add the config option thermostatTemperatureRange="10,30" to the thermostat group. Those values always have to be provided in Celsius!
To map the default thermostat modes of Google (opens new window) (on, off, heat, cool, etc.) to custom ones for your specific setup, you can use the thermostatModes config option on the thermostat group.
E.g. [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" ] will enable the following five modes in Google Home "off, heat, eco, on, auto" that will be translated to "OFF, COMFORT, ECO, ON, auto". You can specify alternative conversions using the colon sign, so that in the former example "BOOST" in openHAB would also be translated to "heat" in Google. For the translation of Google modes to openHAB always the first option after the equal sign is used.
By default, the integration will provide "off,heat,cool,on,heatcool,auto,eco".
Group thermostatGroup { ga="Thermostat" [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false ] }
Number ambientItem (thermostatGroup) { ga="thermostatTemperatureAmbient" }
# Sensor
# Additional Configuration
All device types support checking the current state before sending an updated state by a command. This can be enabled by setting [ checkState=true ] in the metadata. When this is enabled, the current state of the target item is queried and compared to the potential new state triggered by the command. If it is identical, a special error message is triggered and communicated to the user.
add metadata via console:
# Two-Factor-Authentication
For some actions, Google recommends to use TFA (Two-Factor-Authentication) to prevent accidental or unauthorized triggers of sensitive actions. See Two-factor authentication | Actions on Google Smart Home (opens new window).
# Setup & Usage of the Google Home App
- Set up the voice-activated speaker or Android phone (version 6+) with your Google account.
- Start the Google Home app on your phone.
- Go to the settings part:
Home > Settings.
- Press the
+ Add devicebutton in the Settings screen.
- Choose
Works with Google
- Search and select
openHAB.
- Continue with linking your account.
- Login at
myopenhab.orgwith your username and password.
- Make sure to assign your devices to rooms to properly use voice commands.
- You can now control your devices from the Google Assistant and Google Home.
# Example Voice Commands
- Turn on Office Lights.
- Set Office Lights to 35%.
- Open/Close the blinds
- Turn off Pool Waterfall.
- Turn on House Fan.
- Turn on Home Theater Scene.
# Frequently Asked Question
- Say:
Hey Google, sync my devices
- Remove all the metadata.
Switch TestSwitch "Test Switch" { ga="Switch" }- Relink your account.
