# Creating Personal Widgets
# Creating a Widget
WARNING
Note that to add a personal widget to a page or other widget, use the special widget:<uid> syntax for the component type to specify "use this personal widget here".
The config options are the widget's props and the value you wish to assign to each:
prop1: Test
item: Color1
# Widget Structure
The custom widget feature has been designed to be very accessible and users do not require a detailed understanding of webdesign to get started. It may be useful even to beginning users, however, to have a basic understanding of the logical flow of the system. Custom widgets are defined using YAML which is a human readable data format that easily converts back and forth from JSON, a text-based data format widely-used in web applications. MainUI uses the JSON data to populate templates built using Vue, a language for dynamically building HTML, taking advantage of the pre-made components available from the Framework7 (F7) (opens new window) library. The complete flow looks like this:
YAML → Vue (Framework7) → HTML
For basic widgets this information is only sometimes relevant, but when creating more advanced, complex widgets it is often critical to understand this for successful structuring and debugging.
# Component config
Nearly every component will have some aspect that needs to be specified or modified to suit a specific need.
This is accomplished by adding a config section to the component's YAML.
- component: oh-toggle
item: mySwitchItem
Some of the available configuration parameters are specific to a certain component while others, such as visible or class are available in most components.
# Component slots
HTML pages are hierarchically nested.
In order to reflect this structure in the YAML most components will have slots.
To define a component that must be a child (nested inside) of another component you indent the YAML of the child component within one of the defined slots of the first one.
- component: oh-list
- component: oh-list-item
In most cases a component will have a default slot that is the most appropriate slot to use for simple construction.
Some of the components will have more specific slots such as header or content which are rarely used.
# Components
In the custom widget system there are many options for different components to include. Where each component comes from determines many of the options available for configuration and styling.
# openHAB components
The most common type of component in most widgets will be the openHAB (OH) family of widgets. These are modified versions of the F7 library of components. The modifications include themeing to match the MainUI color and style themes and functionality that provides direct interaction with OH features such as Items. A basic description of each of these components and the their capabilities (with examples) can be found on the Component Reference page. Because most of the OH specific components are built on top of the F7 components, the documentation of the F7 components (opens new window) is often useful for users wishing to understand more about the OH components as well.
There are several subsets of OH components, each with different uses and strengths:
- Basic: a component which can be placed within other components (e.g.,
oh-slider) - Standalone Card: a component placed inside a container styled to look like a separate visual element (e.g.,
oh-slider-card) - Cell: a container styled to look like a separate visual element which will expand to show the component when clicked (e.g.,
oh-slider-cell) - List Item: a component placed inside a list type container meant only to be displayed as part of a list and which will not display properly on its own (e.g.,
oh-slider-item) - Specialized components: many of the available page types in the MainUI (e.g., chart pages) have their own series of specialized components
# F7 components
In addition to being the basis for the OH components, the F7 components themselves are available as options in the widget editor. As a general rule, the F7 components will have more configuration and style flexibility than their OH counterparts. So, their use is recommended when there is something about the component that needs to be configured in a way different than what is set in the OH version. Of course, the F7 components do not have the OH specific functions available, so while they can have values based on Items using the expression system, they cannot easily be used to trigger rules, update Items or variables, etc.
The most commonly used F7 components will likely be f7-block, f7-row, and f7-col.
These all generate a simple <div> element with one base F7 class (block, row, and col respectively).
These components are therefore useful as fundamental building-blocks of widget or page.
The list components f7-list-item and f7-list-item-row can often be useful as well given the flexibility they provide for complex structure inside a list.
Any of the OH components that allow widget actions include easy configuration for using some other widget as a popup or popover.
If, however, there is need for the popup or popover to be built-in with a single widget (e.g., to add a widget to the marketplace (opens new window) that includes a popup or popover), the f7-popup and f7-popover component can be used and the open or closed status of that modal object controlled by the popupOpen, popupClose, popoverOpen, and popoverClose properties available in many of the other f7 components and their OH derivates.
# Popup example
- component: f7-card
title: Popup Card
- component: oh-link
text: Open the popup
popupOpen: .demo-pop
- component: f7-popup
class: demo-pop
- component: oh-button
text: Close it again
popupClose: .demo-pop
# Label and Content
There are two special components that are not derived from any other specific library, the Label and the Content component.
These two are similar in their simplicity of configuration, primarily taking only a text property (which can be an expression).
The Label component renders the value given by the text property inside it's own <div> element.
For example:
- component: f7-row
class: fancy-row
- component: Label
text: Label text here
renders in the page HTML as:
<div class="row fancy-row">
<div>Label text here</div>
</div>
Because of this, the Label component also accepts class and style configurations which are applied to the <div>.
Label components are often used extensively in compound widgets with several other components to place informative text.
However, because of the <div> container, there are times and situations where the Label component can cause placement/alignment issues or even configuration issues if the parent element is not compatible with having a <div> container as a child.
In contrast, the Content component renders the value given by the text property without any additional container.
For example:
- component: f7-row
class: fancy-row
- component: Content
text: Content text here
<div class="row fancy-row">Content text here</div>
With no container, there is no possibility to add class or style configuration to the Content component.
# HTML components
The custom widget system can also be used to build HTML more directly.
The component property can also be set to any recognized HTML tag.
When used in this manner, the component accepts any configuration paramaters that can be passed to the tag as HTML attributes (including, of course, class and style).
There is an additional configuration parameter, content which allows for content text to be included in the tag.
HTML components also accept a default slot which will render a child component inside the tag.
# HTML component examples
The widget YAML:
- component: div
content: Make this text bold
font-weight: bold
Renders to the HTML:
<div style="font-weight: bold;">Make this text bold</div>
To put more complex HTML hierarchies, use the component's default slot:
- component: div
font-style: italic
text: "This text starts with italics "
- component: span
content: but then becomes BOLD!
font-weight: bold
<div style="font-style: italic;">
This text starts with italics <span style="font-weight: bold;">but then becomes BOLD!</span>
</div>
# The Expression Syntax
The widget expression system uses a JavaScript-like expression parser, jse-eval (opens new window). In order to remain light-weight and responsive, this is not a complete JavaScript library, but nearly all of the basic function is provided along with some more advanced features.
# Advanced expression features
# Arrow functions
Many standard JavaScript methods take a function as a parameter. The expression parser can parse arrow functions as the parameters of these methods.
Here an arrow function is used in conjunction with the .find() method to locate the item object in an array of items (such as is returned by a oh-repeater) with a particular name.
The label of the found item is then used as the title of a component.
title: =someItemList.find( (x) => x.name=="KitchenSwitch" ).label
# String templates
String templates are a much more human-readable way of creating strings with incorporated dynamic values.
String templates are surrounded by backticks (`string template`) instead of single- or double-quotes.
Inside string templates, variable values can be inserted with ${variable} syntax.
Here the value of the widget property props.page is included in the text of a component by a string template.
text: =`This button opens the ${props.page} page`
# Regular expressions
Regular expressions (regex) allow for complex search or replace string operations.
Many of the JavaScript string methods accept regex parameters expressed as the regex string between two forward slashes (/regex here/).
Here a widget property containing an Item name is searched using regex and the first capture (in this case all characters between two underscores) is returned as a component label.
label: =props.item.match(/_(.*)_/)[1]
# Objects
The variable action allows components in widgets to pass information back and forth when there is user interaction. Often this informtation is simple, such as a single string or input value. Sometimes, however, it is helpful to add more information to a variable and for these instances JavaScript objects are useful. The widget system can create objects in two different ways.
Objects can be defined within the expression system using the standard JavaScript syntax: {'key1':'value1','key2':'value2'}.
Due to the special meaning of :[space] in yaml, it is best to have no spaces between the : and the value.
If you have :[space] anywhere in your expression it will raise a YAML error unless you enclose the entire expression (= included) in another layer of quotes.
Here a variable is set to an object with name and selected keys using the object expression.
actionVariable: myObject
actionVariableValue: ={'name':props.item,'selected':true}
The other way to create objects is to take advantage of the relationship between YAML and JSON and place the key:value pairs as YAML keys under the initial key.
Here is a variable definition with the same results as the one above using the YAML syntax.
selected: =true
In both cases, the variable can now be referenced by other components as vars.myObject with keys vars.myObject.name and vars.myObject.selected.
The object expression can also be used to simulate a switch control statement.
The most common flow control statement in the expressions is the conditional (ternary) operator which is very efficient for selecting from two options based on a single boolean criterion.
If you have a list of possible options, you can string multiple ternary operators together, but this grows cumbersome very quickly.
For example, if there is an HVAC with a mode item that can be set to heat, cool, auto, and off modes, it requires 4 nested ternary operators to set a component's background color to match the current HVAC mode (with a fall back option if the item has some other state, e.g. null).
background: =(@@hvacModeItem == 'heat')?'orange':(@@hvacModeItem == 'cool')?'blue':(@@hvacModeItem == 'auto')?'green':(@@hvacModeItem == 'off')?'white':'red'
To use an object instead, simply create an object with keys for each of the Item's expected states, and give each key the desired output value.
Referencing that object using the Item's state will return the desired value and following that with a simple OR statement will provide the fallback condition if the object reference is undefined.
background: =({'heat':'orange','cool':'blue','auto':'green','off':'white'})[@@hvacModeItem] || 'red'
