# Tips and Tricks
# Backups
When installed on Linux there will be an openhab-cli command line tool that supports backup and restore.
For other systems, under $OH_HOME/runtime/bin you will find backup.sh and restore.sh (or .bat).
# Don't Wait, Try it Out!
# Developer Sidebar
Note that the sidebar will not come up if your display is too narrow. It will not work on a phone nor in portrait mode on most tablet displays.
There are four tabs on the sidebar, and the search field at the top.
# Search
Imagine you need to find all usages of an Item in rules or pages. You could open all your rules and pages to check them, or just use the developer sidebar search. Enter your Item name, and you will see in which rules, scenes, scripts and pages that Item is used.
The developer sidebar search ignores case and searches inside the following entities:
- Things
- UID
- label
- Items
- name
- label
- tags (requires exact match)
- metadata
- Pages
- uid
- label
- content (widgets, tabs, charts, etc. with their configuration)
- Transformations
- uid
- label
- type
- Rules, Scenes & Scripts
- Item name & Thing UID of triggers, actions & conditions
- script code (e.g. Rules DSL, JavaScript, and even Blockly)
- script MIME types (requires exact match)
- Blockly scripts (using 'block', 'blockly' or 'blocksource' as search string, where case is ignored)
- Persistence Configurations:
- label & service id of persistence service
- Items persisted by persistence service
# Pinned Objects
Let's say you are working on your lighting automations which involves Things, Items, and Rules. Instead of keeping a dozen browser tabs open and flipping between them you can pin these objects to the sidebar.
Enter a search term in the search filed at the top to search within Items, Things, Rules, Scripts, Scenes and Pages. The search term can be part of an object's name, ID, label, etc.
Once you've pinned all the objects you want, click the x icon in the search bar.
# Event Monitor
The list is OR meaning is any one matches the event will be shown.
For example, entering *Hum* would only show those events that include "Hum" in the names.
# Code Tools
# Expression Tester
# Scratchpad
# Create Shortcuts
# Consider the logs
# Save Examples
# Where's it all Being Saved?
Everything presented in this tutorial is "managed" and saved to a text based JSON formatted database in $OH_USERDATA/jsondb.
# API
# Asking for Help
- provide lots of details
- be polite.
